I’m troubleshooting slow Save/Autosave times in Rhino 8 on a large, complex scene (100+ layers, nested blocks, mirrored copies, many texture-mapped objects) and comparing behavior against Rhino 9 WIP on the same file.
Setup:
- Rhino 8 Commercial, Windows 11
- NVMe drive: Samsung 990 PRO 2TB
- During save, disk activity (Task Manager) stays under 5% the whole time — so the process is clearly not I/O-bound
- Textures are set to not embed (
RendererSupport.NeverEmbedFiles= True in Advanced Settings), so texture embedding is not a factor in these numbers
Baseline comparison:
- Rhino 8 native Save: file ~340 MB, takes ~20 seconds
- Same scene opened in Rhino 9 WIP, Save As back to Rhino 8 format: file comes out larger (~1.4 GB without textures — worth noting Rhino 9’s save produces a bigger file for the same content), but completes in ~5 seconds
Testing Advanced.UseCompressionWhenSaving in Rhino 8:
- Default (True): file ~340 MB, save ~20 seconds
- Disabled (False): file grew to ~570 MB as expected, but save time increased to ~30 seconds instead of decreasing
- Reverted back to True (default): save time got worse still, ~60 seconds — worse than before touching the setting at all, same file, same session (Rhino was restarted between some of these tests, not all)
So toggling this setting made things worse in both directions rather than showing a clean time/size trade-off, which doesn’t match a simple “compression costs CPU time, disabling it should speed things up” model.
Questions:
- Is
UseCompressionWhenSavingexpected to have a large effect on save time, or mainly on file size? My results don’t show a clean trade-off in either direction. - Could toggling this setting mid-session (even across an app restart) leave a document in a degraded state, e.g. requiring a completely fresh file (re-imported/rebuilt) to reset save performance? Or is there some other document-level state (undo history, render mesh cache, etc.) that could be accumulating and independently slowing saves over a session?
- With texture embedding ruled out and disk I/O confirmed minimal, what does Rhino 8’s save routine spend CPU time on for a scene like this? Is there any way to profile or log what’s happening during that 20-60 second window?
- Is Rhino 9 WIP’s much faster save (~5 seconds vs ~20-60 seconds) from a rewritten serialization/save path, or could it largely come down to different defaults for settings like this one?
This is a real workflow issue since autosave triggers every few minutes on this project, and each freeze disrupts work. Any pointers — even just the right diagnostic tool, log file, or command to inspect what’s happening during save — would help a lot.
