Save model optimcrosec and re-analyse whit other load
good evening, is it possible to save the model obtained through optimcrosec and re-analyse it? for example by putting other loads on the model obtained from the optimcrosec component? Let me explain better, optimcrosec component gives me a result of a structure, analyzed with gravity and variable loads, I would just like to know the deformation relating to the variable loads of the model obtained from karamba, therefore without the gravitational ones
Thank you!
Hi, yes, you can disassemble the model, then reassemble the model with the same elements, materials and cross sections but apply additional loads.
