Save geometry in grasshopper
Hello.
Is there any way to “save” a geometry in grasshopper. As an example let’s say I have a curve and a number slider. The number slider defines the bend of the curve and whenever I move the number slider, the curve bends.
What I am trying to figure out is, if there’s any way to store every iteration of the curve so I can evaluate them afterwards.
Thanks
Instead of a number slider you can use a Range or Series to feed multiple values, then work on all of those.
You can also connected a Curve component, then right click → Internalise Data to “save” the curve in that component.
