Animating a slider is particularly annoying. I set up a viewport with a named view. In the dialog I need to select the camera and then also specify a folder which more often than not has the same name.
Is there possibly a way to script a slider animation?
I do agree the whole thing is old and unfriendly.
The animation should run without necessarily saving. This way you could see and test the animation several times, and make the settings for saving only once when you’re ok with the result.
