Save custom data to Rhino App
is there a way to save custom data to Rhino app or Rhino Settings? Thanks a lot.
What kind of data @Robin3? Simple strings? Complex Objects?
Thanks csykes, a simple string will work, any ideas? Thanks a lot!
I tried the below codes to save a settings, but next time when I debug the plugin, the settings was not there, still plmSettings is null, any ideas? Thanks a lot!
        var pluginSettings = RhinoPlugin.Instance.Settings;
        PersistentSettings plmcSettings = null;
        pluginSettings.TryGetChild("PLMC_Settings", out plmcSettings);
        if (plmcSettings == null)
            appSettings.AddChild("PLMC_Settings");
            appSettings.SetBool("PLMC_Settings", true);
            RhinoPlugin.Instance.SaveSettings();
Hi @Robin3,
Maybe something like this?
public class TestClass
  public bool TestValue { get; set } = true;
  public void LoadSettings()
    try
      var settings = RhinoPlugin.Instance.Settings.GetChild(nameof(TestClass));
      if (null != settings)
        if (settings.TryGetBool(nameof(TestValue), out bool value))
          TestValue = value;
    catch
      // Do nothing
  public void SaveSettings()
    try
      var settings = RhinoPlugin.Instance.Settings.AddChild(nameof(TestClass));
        settings.SetBool(nameof(TestValue), TestValue);
    catch
      // Do nothing
– Dale
Let me try, Thanks Dale!
You right, my bad, I set the bool to the wrong settings, it works fine now. Thanks Dale!!!
