I was wondering if it would be possible to add a “Save Copy” option. This would be used when you want to share a current model with a colleague or a friend and you don’t want to close everything. It will also allow you to choose a location and a filename (incremental saving is not that convenient). Save As becomes a bit of a pain as it changes the file path you are working from.
Hi Miguel - I’ve asked for this as well - it’s on the pile somplace… I typed SaveACopy and got some action here so aparently I made a script or something in the past that is loading at startup. I’ll find it and attach ot here- the UI is not very smooth but it might be OK for now, I’ll try to make a cleaner one.
