Every time I open a Rhino 6 file and click save as , the default “save as file type” is Rhino 6. I want to get this to default to Rhino 5 automatically every time to avoid manually changing it. I tried typing “-saveas” in the command line and then set the version from 6 to 5. But after i restart Rhino , that command resets. Does anyone else know how to change this ?
Hello - you’ll have to use a macro
! _-SaveAs _Version=5 _Browse
Will this open the field so i can enter the file name ?
When i mean “field” i mean the page that opens after you select save as and it lets you find the folder you want to save it in and then put a file name and file type
Yes, that’s what the “Browse” part does.
