I’m trying to save my doc as a copy with RhinoCommon for rhino6 (It’s meant to be a background backup).
At the moment I’m doing this:
Dim BackupName As String = CombinePath(AutoSaveDirectory, Date.Now.ToString("yy-MM-dd-HH-mm-ss-") & doc.Name)
Dim Opt As New FileIO.FileWriteOptions With {
.WriteUserData = True,
.IncludePreviewImage = False,
.SuppressDialogBoxes = True
doc.WriteFile(BackupName, Opt)
But it changes doc.Path to the new name, which obviously is wrong for a backup.
Any idea?
Hi @Dale, i tried the new SR5 function doc.Write3dmFile(path,FileWriteOption) and it raise an unmanaged exception: System.AccessViolationException : 'Tentative de lecture ou d'écriture de mémoire protégée. Cela indique souvent qu'une autre mémoire est endommagée.'
With the same path (I target a directory on desktop) I did not have this issue with doc.WriteFile(path,FileWriteOption)
And this exception is not caught by a try-catch loop, so it makes the program crash.
Here is my full code:
'Save code
If doc.Name = "" Then Exit Sub
Dim BackupPath As String = My.Computer.FileSystem.CombinePath(AutoSaveDirectory, Date.Now.ToString("yy-MM-dd-HH-mm-ss-") & doc.Name)
RhinoApp.WriteLine("MSP: AutoSaving project to ""{0}"".", AutoSaveDirectory)
'TODO: check rhino version (need v6.5)
BackupPath = BackupPath.Replace("\", "\\")
Try
If doc.Write3dmFile(BackupPath, Opt) = True Then
RhinoApp.WriteLine("Next Save in {0} seconds", AutoSaveInterval)
Else
RhinoApp.WriteLine("AutoSave failed and will be disabled.")
Me.Settings.SetBool("MSP_Setting_AutoSaveEnabled", False)
End If
Catch ex As Exception
MsgBox(ex.Message, MsgBoxStyle.Exclamation, "MSP Autosave error")
End Try
Protected Overrides Function RunCommand(ByVal doc As RhinoDoc, ByVal mode As RunMode) As Result
If String.IsNullOrEmpty(doc.Path) Then
Return Result.Nothing
End If
Dim path = IO.Path.GetDirectoryName(doc.Path)
Dim fname = IO.Path.Combine(path, EnglishName() + ".3dm")
Dim fwo As New FileIO.FileWriteOptions With
Try
If doc.Write3dmFile(fname, fwo) = True Then
RhinoApp.WriteLine("{0} saved successfully.", fname)
Else
RhinoApp.WriteLine("{0} save failed.", fname)
End If
RhinoApp.WriteLine(ex.Message)
End Try
Return Result.Success
End Function
Hi @Dale,
I did a few more tests, it seems the crash occurs because my save code is in a .net timer event. (As a manual command your code works fine).
If I use exactly your code from the timer event, it crashes with a protected memory error, while if I just change doc.Write3dmFile to doc.WriteFile it works. Could it be caused by a memory / Hard drive access different between the two methods?
