I would really appreciate your help on this.
I got the SampleNewFloatingViewport implemented in my comand, in my C++ plugin. When I launch the comand, sometimes the ending result isn’t correct, and I end up with a Viewport newly created, but that wasn’t renamed properly.
The only thing that I changed was saving the currentContext.m_doc in a CRhinoDoc* pointer, called currentDoc, and removing the view->FloatRhinoView(true), because I don’t need it:
CRhinoView* RhinoViewsManager::createNewView(ON_wString viewName)
ON_SimpleArray<ON_UUID> viewport_ids;
ON_SimpleArray<CRhinoView*> view_list;
CRhinoView* view = 0;
int i = 0;
// Build a list of (current) viewport ids
currentDoc->GetViewList( view_list, true, false );
for( i = 0; i < view_list.Count(); i++ )
CRhinoView* view = view_list[i];
if( view )
viewport_ids.Append( view->ActiveViewportID() );
view_list.Empty();
// Create a new view
currentDoc->NewView( ON_3dmView() );
// Find the viewport (id) that was just created
for(int i = 0; i < view_list.Count(); i++ )
if( view )
int rc = viewport_ids.Search( view->ActiveViewportID() );
if( rc < 0 )
break;
else
view = 0;
// Make the necessary updates.
if( view )
ON_3dmView v = view->ActiveViewport().View();
v.m_name = (viewName);
view->ActiveViewport().SetView( v );
view->Redraw();
return view;
As I said, sometimes the program doesn’t update the view name, probably because it doesn’t enter in the “if(view)” block. Is that possible?
Plus, another question, is it permissible to save the currentContext.m_doc pointer as I did, or it is a thing that absolutely must not be done? (because it changes too much?)
Thank you for your help
