writing a PDF from a picture in RhinoView, with rastermode true, get a Runtime Error. First writing is ok. Additional there is no error when it was run in a RhinoPlugin. Now, it should be executed directly and written several times. RhinoInside is using.
Code:
ViewHelper.GetCurrentView().ActiveViewport.SetProjection(DefinedViewportProjection.Top, "", true);
ViewHelper.ZoomExtendsAllViews();
ViewHelper.SetViewDisplayMode(ViewHelper.GetCurrentView(), DisplayModeDescription.GetDisplayMode(DisplayModeDescription.GhostedId));
var pdf = Rhino.FileIO.FilePdf.Create();
//A3 Size
var size = new System.Drawing.Size(2970, 4200);
int dpi = 254;
var viewCaptureSettings = new ViewCaptureSettings(activeView, size, dpi);
viewCaptureSettings.OutputColor = ViewCaptureSettings.ColorMode.DisplayColor;
viewCaptureSettings.SetModelScaleToValue(1.0);
viewCaptureSettings.RasterMode = true;
pdf.AddPage(viewCaptureSettings);
string filePath = folderPath + "\\ exportPDF.pdf";
pdf.Write(filePath);
Error:
System.Runtime.InteropServices.SEHException
HResult=0x80004005
Nachricht = Eine externe Komponente hat eine Ausnahme ausgelöst.
Quelle = RhinoCommon
Stapelüberwachung:
bei UnsafeNativeMethods.CRhinoPrintInfo_VectorCapture(IntPtr constPrintInfo, SetClipRectProc clipRectProc, FillProc fillProc, VectorPolylineProc polylineCallback, VectorArcProc arcCallback, VectorStringProc stringCallback, VectorPolylineProc bezCallback, VectorFillPolygonProc fillPolyCallback, VectorPathProc pathCallback, VectorPointProc pointCallback, VectorBitmapProc bitmapCallback, VectorRoundedRectProc roundedRectCallback, VectorClipPathProc pathProc, VectorGradientProc gradientProc, UInt32 docSerialNumber)
bei Rhino.Runtime.ViewCaptureWriter.Draw(IntPtr constPtrPrintInfo, RhinoDoc doc) in Rhino.Runtime\ViewCaptureWriter.cs: Zeile126
bei ExportPDF.PdfDocumentWriter.AddPage(ViewCaptureSettings settings) in D:\BuildAgent\work\commercial\src4\rhino4\Plug-ins\export_PDF\ExportPDFPlugIn.cs: Zeile939
bei Construction.Tools.PDFExportToolViewModel.ExportPDF() in C:\Users\...\UserControls\Construction\Tools\PDFExportToolViewModel.cs: Zeile369
bei Construction.Tools.PDFExportToolViewModel.<get_ExportPDFCmd>b__32_0(Object param) in C:\Users\...\PDFExportToolViewModel.cs: Zeile252
bei RelayCommand.Execute(Object parameter) in C:\Users\...\RelayCommand.cs: Zeile50
bei MS.Internal.Commands.CommandHelpers.CriticalExecuteCommandSource(ICommandSource commandSource, Boolean userInitiated)
bei System.Windows.Controls.Primitives.ButtonBase.OnClick()
bei System.Windows.Controls.Button.OnClick()
bei System.Windows.Controls.Primitives.ButtonBase.OnMouseLeftButtonUp(MouseButtonEventArgs e)
bei System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
bei System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
bei System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
bei System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
bei System.Windows.UIElement.OnMouseUpThunk(Object sender, MouseButtonEventArgs e)
bei System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
bei System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
bei System.Windows.Input.InputManager.ProcessStagingArea()
bei System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
bei System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
bei System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
bei System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
bei System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
bei MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) in MS.Win32\HwndWrapper.cs: Zeile221
bei MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o) in MS.Win32\HwndSubclass.cs: Zeile255
bei System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs) in System.Windows.Threading\ExceptionWrapper.cs: Zeile81
bei System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler) in System.Windows.Threading\ExceptionWrapper.cs: Zeile31
bei System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs) in System.Windows.Threading\Dispatcher.cs: Zeile1401
bei MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam) in MS.Win32\HwndSubclass.cs: Zeile207
bei MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
bei System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame) in System.Windows.Threading\Dispatcher.cs: Zeile1720
bei System.Windows.Application.RunDispatcher(Object ignore)
bei System.Windows.Application.RunInternal(Window window)
