Felix1
#1
i try to run the export command with a pytthon script. If i running the script in debug_mode from the editor it is working fine
Rhino.RhinoApp.RunScript(command, True) returns True
but if i link the script to a button it stop working.
Rhino.RhinoApp.RunScript(command, True) returns False
I think it is part of this problem: http://developer.rhino3d.com/guides/rhinocommon/run-rhino-command-from-plugin/
The problem is that i dont know how to implement this with python
dale
(Dale Fugier)
#2
Hi @Felix1,
Can you provide a small sample script file that works inside of the EditPythonScript
editor but does not work with the RunPythonScript
command?
– Dale
Felix1
#3
I didnt used “RunPythonScript” so far. With this command it works but it is not really what i want.
I buddled my script with a python-plugin so that i could call it direct.
As example:
Example_cmd.py (3.3 KB)
i like to run it just call “Example” inside the console
