Runscript + browse?
I wanted to temporarily resuscitate some old VB Rhinoscripts, but first to test them, I wanted to run them with the LoadScript command - they are already set to run immediately when loaded.
This works from an alias or button:
_-Loadscript "FullPathToFile\Filename.rvb"
However, if I want to browse to the file in a directory… I can’t do it in one go. If I type
_Loadscript
I get a file dialog where I can browse to the file - but it doesn’t run afterwards, I have to load the file, close the dialog, then use
_Runscript
and find the loaded file in the list in order to run it.
_RunPythonScript on the other hand immediately opens a browser window to find a script and when the file is chosen, it runs immediately - i.e. not a two-step process. It’s been so long… What have I forgotten?
From way back:
– Dale
OK, so it looks like the only way to be able to browse to a script (with a Windows browser window) is via EditScript, then run the script from there.
I’m probably going to “pythonize” these anyway.
