Run PythonScript without GUI
Hello everyone,
I’ve written a Python script which allows me to generate a geometry based on a number of variables. All I have to do is start Rhino, set the variables and run the script. I was wondering if it was possible to run the PythonScript without ever starting the GUI, preferably from CMD or Powershell. All imports exports are automated anyway.
Does this help?
I’m pretty sure that this should allow me to pull this off.
This does not work from Powershell but it does work from CMD.
However the -RunPythonScript simGen.py -exit command does not close Rhino. Rhino remains open. It seems to try and run the -exit command as part of the Python Script
Also, isn’t it possible to run it without the GUI?
OK so it can now be done if I use rs.Exit() in the python script.
But this still requires a GUI. I want Rhino to stay closed, basically just doing it’s thing silently without ever popping up in my screen. Is this possible?
I don’t know a way to do this. Have you disabled redraw to minimise the cost of the gui?
Hi @SNC,
To “run” Rhino without a GUI, you’ll need to automate Rhino using ActiveX automation.
https://developer.rhino3d.com/api/rhinoscript/introduction/external_access.htm
Here are a couple of examples you can review:
https://github.com/mcneel/rhino-developer-samples/blob/6/rhinoscript/RhinoRender.vbs
https://github.com/mcneel/rhino-developer-samples/blob/6/rhinoscript/TestRhino6Automation.vbs
https://github.com/mcneel/rhino-developer-samples/tree/6/rhinocommon/cs/SampleCsAutomation
https://github.com/mcneel/rhino-developer-samples/tree/6/cpp/SampleAutomationClient
– Dale
Why don’t you try rhino3dm and compute-rhino3d modules for CPython?
Thanks. I’ll give it all a try!
Very interesting! Would this work for open many dxf files in Rhino, deleting all points and exporting each one as a 3dm file? I’m looking for a way to do this without opening the GUI as the millions of points in each file make it extremely slow.
Thank you in advance!
Quick search gave me this result:
This is supposedly a module that will allow you to create and modify DXF files.
Should be better solution.
simple example of deleting all points in dxf file:
import sys
import ezdxf
try:
    doc = ezdxf.readfile("points_.dxf")
except IOError:
    print(f"Not a DXF file or a generic I/O error.")
    sys.exit(1)
except ezdxf.DXFStructureError:
    print(f"Invalid or corrupted DXF file.")
    sys.exit(2)
model_space = doc.modelspace()
for e in model_space:
    if e.dxftype() == "POINT":
        print(e.dxf.get_default("location"))
        doc.entitydb.delete_entity(e)
doc.saveas("no_points_.dxf")
Yes this should work well ! ezdxf works well and you can quite easily delete all points, then save back to dxf before opening the dxf in Rhino.
