Is there a way in Grasshopper to pause the execution of the graph while I do some changes? I am dealing with a huge amount of data & everytime I change a minor part, it executes right away and freezes for a few seconds.
I came from Dynamo - Revit workflow & got used to this function, so I am not sure what would be the equivalent of this in Grasshopper.
Please help!
Yes, it’s called “Disable Solver” or “Lock Solver” and can be found in the right-click menu, the radial menu, as well as the menu bar under “Solution” (at least on macOS).
