I want to select Multiple objects then export it to DXF.
After I get the Objects… the command seems to be stuck at Select Object. And When I want to run the command to export the selected object to a file. Here is the code:.
// Check the selected dot
GetObject go = new GetObject();
go.GroupSelect = true;
go.SubObjectSelect = false;
go.EnableClearObjectsOnEntry(false);
go.EnableUnselectObjectsOnExit(false);
go.DeselectAllBeforePostSelect = false;
go.EnableSelPrevious(true);
go.EnablePreSelect(true, false);
go.EnablePressEnterWhenDonePrompt(false);
go.SetCommandPrompt("Select objects and a label to export as .DXF:");
GetResult result = go.GetMultiple(1,-1);
if (go.CommandResult() != Rhino.Commands.Result.Success)
return go.CommandResult();
RhinoApp.WriteLine("Total Objects Selected: {0}", go.ObjectCount);
string labelName = null;
// Loop through all the objects to find Text
for (int i = 0; i < go.ObjectCount; i++)
RhinoObject rhinoObject = go.Object(i).Object();
if(rhinoObject.ObjectType == ObjectType.Annotation)
TextEntity textEntity = rhinoObject.Geometry as TextEntity;
if (textEntity != null)
labelName = CleanString(textEntity.Text) +".dxf";
if(labelName == null)
return Rhino.Commands.Result.Failure;
String path = Path.GetDirectoryName(doc.Path);
// Export the whole lot
string command = string.Format("-_Export \"" + Path.GetDirectoryName(doc.Path) + @"\" + labelName + "\" Scheme \"R12 Lines & Arcs\" Enter");
// Export the selected curves
RhinoApp.RunScript(command, true);
return Result.Success;
The Command only display “-_Export”
After selecting the objects, how do you get out from that command so that the next command can be executed?
