my component “rules generator” for wasp is not working. it gives me an error “no rules provide”. has anyone ever gotten this error?
Do you have the most recent version of wasp installed? The current Rules Generator component does not have an error message if no rules are provided. The component is meant to generate rules based on a set of parts with their connections defined or based on a set of parts and an additional provided rule grammar.
In any case, it really helps us to help you if you provide example files or screenshots showing your problem.
For further questions I recommend you to take your question to the dedicated discord server for WASP:
Andrea, the developer of wasp, is very active on there and your question will most probably get solved very fast.
Hope that helps.
