I just got this error after opening Rhino V6…
Afterwards Rhino looks like this:
Any idea on what’s going on or how to fix this?
For the developers FWIW:
Last week I got an error that the MRU toolbar could not be written to. I attributed it to closing 2 instances in close succession. It might be unrelated to this, but maybe it’s a clue. I did not report it because I was working on a time critical project.
-Willem
Hi Siemen,
If Im not mistaken, As a fix you can run the command ToolbarReset.
HTH
-Willem
Thanks Willem,
That indeed did the trick.
I get this as well - it is on the heap…
https://mcneel.myjetbrains.com/youtrack/issue/RH-37752
thanks,
