I like to create individual polylines around all of my elements. Minus the inner corners.
I have managed to get the point in each elements that i like to connect. But im not able to connect em without making a tons of random lines.
Can you please help?
if you remove the grafting the output B of the Dispatch you’ll get a data tree where points that belong to the very same shape are inside the very same branch
after that, a Polyline component (with ClosePolyline option enabled) will do the trick:
I can see there is one very small issue. Two of the elements came imported with a rectangle inside.
Now they kind of are inside out.
I have tried to attached a point after the dispatch to highlight the issue.
Do you have any idea why?
