Is there any way to visualize RTree method coming from RhinoCommon similar to original Wikipedia description?
I don’t think so with RhinoCommon, because you don’t have access to the tree nodes. In C++ it can be done.
Thanks Menno I ll give a go to C++
Is there any sample in McNeel github page as well?
Not that I can see. I know I have some code that uses it on my company laptop, I can post something on Monday.
Thanks;)
Thank you, do you think c++ sdk allows to vizualize the rtee node hierarchy? Would it be possible to tell me which property I should look at?
Below you find a working example, maybe @dale can put it up on github?
bool HandleTreeNode(const ON_RTreeNode* node, ON_SimpleArray<ON_BoundingBox>& boxes)
// a tree node contains m_count branches
for (int i = 0; i < node->m_count; ++i)
const ON_RTreeBranch& branch = node->m_branch[i];
// each branch has a bounding box in m_rect: this is what we want to see
const ON_RTreeBBox& box = branch.m_rect;
// add the bounding box to the boxes array
ON_3dPoint minPt(box.m_min);
ON_3dPoint maxPt(box.m_max);
ON_BoundingBox bbox(minPt, maxPt);
boxes.Append(bbox);
// if the node is not a leaf node, recurse to the next level
if (!node->IsLeaf())
HandleTreeNode(branch.m_child, boxes);
return true;
CRhinoCommand::result CCommandClass::RunCommand( const CRhinoCommandContext& context )
CRhinoGetObject gp;
gp.SetCommandPrompt(L"Select points");
gp.SetGeometryFilter( CRhinoGetObject::point_object);
CRhinoGet::result gr = gp.GetObjects(1,0);
// create the R-tree from the input points.
ON_RTree tree;
if (gr == CRhinoGet::result::object)
for (int i = 0; i < gp.ObjectCount(); ++i)
auto obj = gp.Object(i);
const ON_3dPoint& pt = obj.Point()->point;
tree.Insert(pt, pt, i);
else
return CRhinoCommand::success;
ON_SimpleArray<ON_BoundingBox> boxes;
// call the recursive method to extract the boxes,
// starting at the root of the tree
HandleTreeNode(tree.Root(), boxes);
// add the boxes to the document as meshes.
const int nBoxes = boxes.Count();
for (int i = 0; i < nBoxes; ++i)
ON_BoundingBox& bbox = boxes[i];
// skip coincident bounding boxes
if (bbox.m_min == bbox.m_max) continue;
// check for planar bounding boxes
bool isPlanar[3] = {false,false,false};
for (int i = 0; i < 3; ++i)
if (bbox.m_min[i] == bbox.m_max[i])
isPlanar[i] = true;
break;
// add planar bounding boxes as a mesh face.
ON_SimpleArray<ON_3dPoint> corners;
if (isPlanar[0])
corners.Append(ON_3dPoint(bbox.m_min[0], bbox.m_min[1], bbox.m_min[2]));
corners.Append(ON_3dPoint(bbox.m_min[0], bbox.m_max[1], bbox.m_min[2]));
corners.Append(ON_3dPoint(bbox.m_min[0], bbox.m_max[1], bbox.m_max[2]));
corners.Append(ON_3dPoint(bbox.m_min[0], bbox.m_min[1], bbox.m_max[2]));
else if (isPlanar[1])
corners.Append(ON_3dPoint(bbox.m_max[0], bbox.m_min[1], bbox.m_min[2]));
corners.Append(ON_3dPoint(bbox.m_max[0], bbox.m_min[1], bbox.m_max[2]));
else if (isPlanar[2])
corners.Append(ON_3dPoint(bbox.m_max[0], bbox.m_max[1], bbox.m_min[2]));
if (corners.Count() > 0)
ON_Mesh face;
if (RhinoMeshFace(face, corners))
if (face.IsValid())
context.m_doc.AddMeshObject(face);
else // add non-planar bounding boxes as boxes.
ON_3dPoint meshCorners[8];
meshCorners[0] = ON_3dPoint(bbox.m_min[0], bbox.m_min[1], bbox.m_min[2]);
meshCorners[1] = ON_3dPoint(bbox.m_min[0], bbox.m_max[1], bbox.m_min[2]);
meshCorners[2] = ON_3dPoint(bbox.m_max[0], bbox.m_max[1], bbox.m_min[2]);
meshCorners[3] = ON_3dPoint(bbox.m_max[0], bbox.m_min[1], bbox.m_min[2]);
meshCorners[4] = ON_3dPoint(bbox.m_min[0], bbox.m_min[1], bbox.m_max[2]);
meshCorners[5] = ON_3dPoint(bbox.m_min[0], bbox.m_max[1], bbox.m_max[2]);
meshCorners[6] = ON_3dPoint(bbox.m_max[0], bbox.m_max[1], bbox.m_max[2]);
meshCorners[7] = ON_3dPoint(bbox.m_max[0], bbox.m_min[1], bbox.m_max[2]);
ON_Mesh* boxMesh = RhinoMeshBox(meshCorners, 1, 1, 1);
if (nullptr != boxMesh && boxMesh->IsValid())
context.m_doc.AddMeshObject(*boxMesh);
Very nice, thank you so much
Since you have experience with C++ an RTree, it seems to give much more freedom.
In C# Rtree is limited to points and bounding boxes.
Do you think it is possible extend C++ RTree to work with oriented-bounding-boxes as well?
Or have you been using C++ RTree with other data-structures rather than point-clouds or boundingboxes?
No, also in C++ the bounding boxes in the datastructure are always axis-aligned, the ON_RTreeBBox
struct only contains the min,max points that define the axis-aligned bounding box.
So far I only used point-clouds or bounding boxes. The R-tree is a spatial search acceleration tool that helps you to speed up finding things in a certain region of space without having to do a full search.
May I ask ageneral question related to the code:
Do I need to paste the code in VS and wrap it there in a plug-in or are there other ways?
Thanks in advance!
You need to paste it in rhino c++ commandline plugin
Would you have time to help me on another RTree issue? I am trying to learn basics how to find all unique pairs colliding within bounding boxes without duplicate pairs when a==b is the same as b==a:
