After the latest update, in a ghpython script component, Trimbrep won’t output a guid anymore. The output refuses to be processed by other methods like volume or volumecentroid. Workarounds? Or is it a bug, or am I doing something wrong?
@Alain have there been recent changes to this function?
Hi Florin- the function returns a list of GUIDs, not a single GUID. Does that make sense with what you are seeing?
Nope, it outputs a list, but not of guids.
Hi Florin - I get this in the latest build here:
Pascal, you seem to have tested it in the editscript editor with debugging.
Can you please try and test in a ghpy component? I updated less than a week ago.
Sorry, I had misunderstood what @piac wanted and made the function return the breps instead of ids in the context of grasshopper and then forgot to check-in the last changes. I checked in the latest version: https://github.com/mcneel/rhinoscriptsyntax/blob/04da9732a8091a0a2e76ab48f5dfcc0dbe050c36/Scripts/rhinoscript/surface.py#L2040-L2069
