rs.PointInPlanarClosedCurve() vs rg.Curve.Contains()
How can I get this script to run in Rhino common vs rhinoscriptsyntax?
rs.PointInPlanarClosedCurve(pts[i],Curve) returns True and False
but
rg.Curve.Contains(curve, pts[i], plane, 0.001) returns “Inside” and “Outside”
How do I change the logic in this to make the Rhino.Geometry work?
if boolean[i] == True:
ptIn.append(pts[i])
if boolean[i] == False:
ptIn.append(pts[i])
Should I be checking if “Inside” or “Outside” are in boolean first?
I am using the ghPython node in grasshopper.
import Rhino
import random
pts =
for i in range(0,4):
pt = Rhino.Geometry.Point3d(random.uniform(0,10), random.uniform(0,10), 0)
pts.append(pt)
boolean =
ptIn =
ptOut =
for i in range(len(pts)):
pt_in_or_not = Rhino.Geometry.Curve.Contains(curve, pts[i], plane, 0.001)
boolean.append(pt_in_or_not)
#Contains function returns "Inside" and "Outside" NOT True and False
    ptIn.append(pts[i])
    ptIn.append(pts[i])
ptIn_Out = ptIn
ptOut_Out = ptOut
Here is the code behind rs.PointInPlanarClosedCurve():
def PointInPlanarClosedCurve(point, curve, plane=None, tolerance=None):
    """Determines if a point is inside of a closed curve, on a closed curve, or
    outside of a closed curve
    Parameters:
      point (point|guid): text point
      curve (guid): identifier of a curve object
      plane (plane, optional): plane containing the closed curve and point. If omitted,
          the currently active construction plane is used
      tolerance (number, optional) it omitted, the document abosulte tolerance is used
    Returns:
      number: number identifying the result if successful
              0 = point is outside of the curve
              1 = point is inside of the curve
              2 = point in on the curve
    Example:
      curve = rs.GetObject("Select a planar, closed curve", rs.filter.curve)
      if rs.IsCurveClosed(curve) and rs.IsCurvePlanar(curve):
          point = rs.GetPoint("Pick a point")
          if point:
              result = rs.PointInPlanarClosedCurve(point, curve)
              if result==0: print "The point is outside of the closed curve."
              elif result==1: print "The point is inside of the closed curve."
              else: print "The point is on the closed curve."
    See Also:
      PlanarClosedCurveContainment
      PlanarCurveCollision
    point = rhutil.coerce3dpoint(point, True)
    curve = rhutil.coercecurve(curve, -1, True)
    if tolerance is None or tolerance<=0:
        tolerance = scriptcontext.doc.ModelAbsoluteTolerance
    if plane:
        plane = rhutil.coerceplane(plane)
    else:
        plane = scriptcontext.doc.Views.ActiveView.ActiveViewport.ConstructionPlane()
    rc = curve.Contains(point, plane, tolerance)
    if rc==Rhino.Geometry.PointContainment.Unset: raise Exception("Curve.Contains returned Unset")
    if rc==Rhino.Geometry.PointContainment.Outside: return 0
    if rc==Rhino.Geometry.PointContainment.Inside: return 1
    return 2
I might be biting off more than I can chew with trying to convert some rhinoscriptsyntax scripts into Rhino Common, but I am going to try. I hope I don’t bother this forum too much with my questions.
Thank you for the quick response.
Michael
If you are posting code here try the following formatting to make it easier to read/copy:
```python (three "backticks" plus python)
<paste your entire code in here>
``` (three more "backticks")
Will do, thanks
testing…
import Rhino
import random
pts = []
    pts.append(pt)
boolean = []
ptIn = []
ptOut = []
Looks good!
