Here is the offending line of code:
reverse = rs.GetBoolean("Reverse?",(("Reverse", "no", "yes")), (False))
Which produces the following UI:
My question is: what is the textbox and why is it included with the GetBoolean call?
Hi @Jack_Minardi,
The rs.GetBoolean
method uses a RhinoCommon GetOption object to display one or more toggleable options.
Internally, GetOption
inherits from GetString. And since GetString
display the edit field, so does GetOption
Hope this helps.
– Dale
Is the text field used for anything?
No it is not…
