In Windows, rs.DocumentPath() returns the path plus the filename.
On Mac, rs.DocumentPath() returns just the path, without the filename
This obviously can create problems for cross-platform scripts.
if you run the following on both Windows and Mac platforms, you will see the difference:
import scriptcontext as sc
print sc.doc.Name
print rs.DocumentName()
print sc.doc.Path
print rs.DocumentPath()
In Windows you will see the first two and the second two are the same;
on Mac the second two are not the same.
The workaround is obviously not to use DocumentPath() but instead scriptcontext.doc.Path, but perhaps this should be corrected?
Thanks, --Mitch
