Rs.DocumentName() on unnamed document
The help says it should return None. In fact it returns an empty string…
filename=rs.DocumentName()
print "filename is of type: ", type(filename)
if filename==None:
    print "Filename is None"
elif filename=="":
    print "Filename is an empty string"
else:
    print "I have no idea"
So, which should it be returning? None or "" ?
–Mitch
Yes,Rs.DocumentName() return ""Rather than None
I know it does that, the question is whether it should and why…
From rhinoscriptsyntax :
def DocumentName():
    "Returns the name of the currently loaded Rhino document (3DM file)"
    return scriptcontext.doc.Name
It looks like the function simply returns the property
RhinoDoc.Name
which is a string, then I guess it could not return None
Well, it could also be written this way:
def DocumentName():
    if scriptcontext.doc.Name != "" :  return scriptcontext.doc.Name
    return
Of course, that’s whole extra line… :stuck_out_tongue_winking_eye: --Mitch
Hehe … or trying to be terse :
def DocumentName():
    return scriptcontext.doc.Name or None
… This language is fun … :smile:
Yeah, really… :smile_cat:
