Greetings!!
I was working on offsetting the below cad profile
The offset i expected was (need solution which is fully automated in python),
@Michael_Pryor gave a solution using food4rhino clipper library that works very good for me, but its a rhino command, i wanted it like a python code, i coded it with rs.command but there is much complication, please help to get an answer
This is the code i have used,
def offset(curve, length = 5, direction = "Inside"):
##ProjectTo = FitToCurve
rs.Command("_OffsetPolyline " + "_selid " + str(curve) + " _Enter" + " Distance" + " _Enter" + str(length) + " Side" + " _Enter" + str(direction) + " _Enter" + " _Enter" )
curve = rs.GetObject("select curve", rs.filter.curve)
print offset(curve)
Please find the attached cad file below,
find_corner_points.stp (9.9 KB)
Previous forum post : Offset Problem
Thanks in advance
