Hi Guys,
I have ran into an issue i haven’t had before with the project command.
When I project the above curve onto the surface below, the curve suddenly changes to weird sharp angles. I have never had issues with project before, I had even projected the same curve onto a similar surface before doing this one.
Anyone know what’s going on here and how i might fix it?
Thanks in advance
Would be good to have the file with the original curves and the SubD…
Are you very far from the world origin?
Ahhh that was the issue.
I was working with some imported TOPO and Contour data so i was a million miles away from the world origin.
Is there a way for me to move the world origin without effecting the coordinates from imported data? This isn’t the first time I have caused this issue for myself. I sometimes forget that the tools can go a bit strange when far from the origin.
Thanks so much for your help!
You can’t move the world origin, you can only move the model. Here is one workaround:
Awesome, thanks for the workaround!
