Round BREP not shown in Shapediver
Did a super simple script with a few extruded parts (one from rectangle, 4 from circle) All is well in Rhino visually but the round extrusions do not show in Shapediver
If your ShapeDiver account is free, you are uploading to a Rhino 6 system? Did you open your definition in Rhino 6 locally and made sure it works as expected there?
Mm no, i tested on Rhino 7 as I don’t have Rhino 6 installed.
However did some iterative testing seems that the issue was with the offset curve component in GH, i switched to a different way of calculating the base points of the circular extrusions and now i have it working.
