I’m trying to rotate 2 lines (A;C) connected by an other line (B) like in the link below
I want to be able to move the mechanism with one slider if possible, the ends of A and C shoud always be connected to B
Here is a definition with what you asked.
Though i technically didn’t do it like you described, i “rotate” line segment A and B equally and create the line between.
I can imagine that the following questions is how to do it with line segment B having a fixed lenght, right?
Mechanism_Re.gh (5.4 KB)
Yes this is the probem, B must have the same lenght
I don’t know if your intention is to have this equality condition hold and have the points on both circles travel 360 degrees, because that usually won’t happen.
crank.gh (10.9 KB)
