Rotation of gumballs
If I drag to rotate an object with gumball, it will rotate every 90 degrees.
If I hold down shift and drag, it rotates according to the distance of the drag.
I want to reverse this.
Do you know where I can change the setting?
Hi tatsuya - this will follow the Ortho setting.
Yhank you so much!!
