Rotating more than one surface around their own vertical axis
Hello, I have an issue hoping someone helping me. As shown in attached picture and .gh file We have six vertical surfaces and I used shown components to make these surfaces rotate around their own horizontal axes in a range of ( 0 to 90 ) degree in 9 steps ( every 10 deg) so we have 10 new surfaces in each of six surfaces ( totally 60 ). Now what I want to do is to rotate the generated 10 surfaces around its own vertical axes in range of ( -40 to 40 ) I mean that every surface of the generated 10 surface rotate 4 steps right and left each step with 10 deg. So that we can get totally 90 surfaces in each of 6 surfaces ( 540 totally). Could anyone helping plz? Thanks
radwa1.gh (14.5 KB)
IMG-20220517-WA0001
i’m not sure if i’ve misunderstood your terminology, but does this help?
radwa
radwa2.gh (13.8 KB)
radwa1_re.gh (12.0 KB)
Mr @HS_Kim Thanks very much it is helpful. Now I want to ask how can check that these generated 90 surfaces are in the correct tilt angle and azimuth angle ( check that each one of 10 surface rotated correctly on its vertical axis with the defined angles)
