Rotating bricks from image sampler?
I am fairly new to grasshopper and I have been working on a script that is mimicking the Cloaked in Bricks facade.
One of my attempts is below. It is rotating like I want it too, but I want I would like to have a more organic, fluid look like the Cloaked in bricks facade.
Does anyone know how I could use an image sampler to rotate these bricks in specific areas?
Hi keep searching the forum. I’ve seen this question before - it’s out there if you find the right keywords:)
This might be of some help to you.
These all the parametric brick works i did through image sampling I’ll share you the definition image soon.
Thank you, this is helping me further along to figuring it out. Am I able to do this without using a surface? As you can see above in my script I made my bricks with the rectangular component, linear arrayed them, which made the wall and bricks in just one geometry.
Is there a way to turn this into a surface so I can reparameterize it and plug it back into the image sampler?
Find a very quick example attached, based on your definition.
Note: If you can upload your definition (or a portion of it), internalising any referenced data, it is much easier to help. You will also find that you will receive quicker responses.
BrickRotation.gh (148.4 KB)
Edit: It may be less heavy if you rotate the planes/rectangle curves first, then make the solid bricks after.
Hi, do you have the definition of this script?
