How to rotate a viewport on a sheet in Rhino.Inside.Revit?
The Viewport Rotation Parameter is an Enumeration, you can create a Value List [0,1,2] to select the options.
Thank you!
Hello!
What would be the solution in case this message appears in the Element Parameter component?
“Can`t read parameter. ‘Rotation on Sheet’ is read-only.”
Thank you.
