Its very basic and there are several ways to to it, but i never found a super fast way to rotate an object by 90° around it’s center vertical axis. Let’s say you are placing lots of furniture in a big floor plan. The most common thing is (except from moving and copying) rotating the object by 90°. My favorite method is:
click the object,
click the rotation handle in the gumball,
type “90”,
hit enter
done
Is there a way to solve it like:
click object
cmd+R or cmd+L (or a command like “_Rotate90Clockwise”)
done
Ah, nice! I didn’t know _BoxEdit existed. It serves me for other things, thanks a lot!
Unluckily for exactly this kind of issue it is not making my workflow faster… It’s acutally more clumsy than manipulating the gumball.
Dear Pascal, thanks for your lighting fas support! I appreciate it a lot!
Its my first time I used python within Rhino, it worked! =) As well for the macro editor, i never used it so far. I should learn more about it, is so powerful! =)
One question left, is it possible to call this Script with an alias or command?
So nice! Thanks Pascal!
It works as well on the mac =)
I call “rr” (which is my super fast alias )
then hit the spacebar twice and it’s done!
Saves me each time a second, which makes hours in the long run, specially when applying the command to multiple objects! and it’s much more fun like this!
Hi Pascal and thanks a lot for the script. It would be useful to have this feature inside rhino.
It works fine except one thing: if during the selection of the objects I have made a mistake I cannot deselect the wrong ones. Sometimes I can deselecto only some objects…it’s quite strange…
Hmm - so far this works as expected here. Ctr-click to deselect, that is what you mean, correct? Are you interacting with the command line (Angle) at all in the process?
Ah - wait… I am on Windows - hold on a moment.
I see the problem on V5 & V6 for Mac…at least part of the problem seems to be that the other objects are extrusions and not Breps. If I Explode and then Join all the objects or ConvertExtrusion, then selection seems normal.
Hi, I use rhino 6 on windows.
The objects are all primitives and not extrusions.
Sometimes If I put (for exaple) 3 box I can deselect only some of them.
Hi Fabrizio - well, that is odd - I see a clear problem on Mac but on Windows this all seems fine here - can you run SystemInfo in Rhino and post the results?
