Rotate, Mirror or Polar array Text
Hello there
I have tried to use Polar Array (rotate=yes), Rotate Copy, and Mirror text around a circle, but once the text text passes the 180 deg rotation, its reversely rotated (pls see the attached file and the Text shown in red for various examples.)
I assume this is a feature for the text command so that it stays headsup, however I do want the text to following the rotation progressively after passing through the 180deg mark.
Would anyone know a way to override this default?
Thank you so much!
YutakaArray or Mirror Text.3dm (392.7 KB)
Hi Yutaka,
uncheck this box: “Text reads forward…”
Hi Martin
Thank you so much its working now! Btw, great work on your website too, amazing!
Thanks a lot and best wishes!
Yutaka
