Rotate Lunchbox Structure Pattern
How do i rotate a lunchbox Braced Grid 1-D structure 45 degrees so the structure looks like a diagrid structure with bracing in the middle? I need it in structure output (not a panel) so i can link it to Karamba3D.
here the 3d and GH file
Percobaan 23042023.gh (25.7 KB)
Percobaan 23042023.3dm (326.1 KB)
Just Reverse it.
Helo Mr. Quan Li, thank you for your help, but the one i need is structure as the output not a panels, is it posible to make it using diagrid and make bracing in the middle? (also i don’t know the script to make a bracing in the middle of the diagrid that connect to nodes)
