Rotate linked together
In rhinoceros do dog commands to put the pieces together to make up a ball? please help
What is a “dog command”? Does the Orient3Pt command do what you want?
thanks, I tried that command, but it didn’t work as I wanted.
Hi -
How did you create the curves that you want to put together?
Can you post your 3dm file?
ball geometry.3dm (600.1 KB)
I’m trying to combine an existing profile, to make a ball shape
Hi -
From the file that you now posted, it’s not clear to me what the workflow is. You say that this is an “existing profile” - what does that mean? It doesn’t look like all the curves that would produce a sphere are in that file.
I’m trying to give preformed curves so they fit together into a shape over the ball.
thank you, i will try it,
It doesn’t seem to be a command, I searched for it but didn’t have any results. Can you tell me how?
