Rotate hinge as part of Kangaroo solution
Hi People more Kangaroo savy than I :slight_smile:
I have this standard cabinet hinge hooked up in Kangaroo and if I drag the parts, they do exactly as they should. I’ve been trying to find a way to rotate the part inside the yellow markings to a specific angle around the red axis, but can’t get the whole Kangaroo solution to follow suit. I simply don’t know how rotate the part “numerically” after making it a rigid body.
I’m still very much a novice in GH and Kangaroo, so it might be something fairly simple, but I can’t find an example to follow/copy/steal from :upside_down_face:
TIA, Jakob
Edit: This is obviously only half the hinge for the visualisation’s sake.
funirture door hinge GH rigged.gh (2.9 MB)
Have you come across this example Jakob:
Basically you set up a rotating point as an anchor. I could have a go at adapting your definition, but this might be enough for you to be able to do it.
Perfect @johnharding! I’ll have a go at it! Thanks a lot!
-Jakob
It worked perfectly, @johnharding! Thanks for the pointer :slight_smile:
-Jakob
:smiley:
furniture-hinge-ani
