Rotate gradient hatch
Rotation of gradient hatch does not do anything. Add, Edit, and Remove buttons don’t seem to work either. Is this a known bug?gradienthatchwontrotate3dm.3dm (235.4 KB)
Hello -
I see that - you’ll need to directly edit the stops, for the gradient itself. The rotation applies to the hatch pattern if any - it should probably be grayed out for solid hatches.
RH-63227 Hatch: Gray out Rotation for solid hatches
Remove etc works here - it should send you into the viewport to directly manipulate the points in the gradient in place - do you not see that?
Thanks Pascal, that was the trick.
