I want to rotate this Surfaces in the center so that the normal is in the direction of a point (sun)
3D_modell Seminar_MORPHSUITS.3dm (3.5 MB)
Solar pattern.gh (433.1 KB)
yes thank you much
But… because the sun is effectively an infinite distance away, all circles will be parallel with identical azimuth and altitude angles (normals). Unless you’re trying to “focus” the sun rays on a nearby point?
yes, you are right I need one angle and all should be look in this one direction
