While using these commands, if you toggle to copy yes, place some copies and then toggle back to no, Rhino remembers the yes option when you recall the command.
Can we have Rhino remember the last state used?
This problem is now in our bug track system as RH-20842 and scheduled to be in the first V6 beta.
Thank you for telling us.
ā Dale Lear
The persistence of Copy for both the Rotate and Rotate3D commands is controlled by the RememberCopyOptions command. The command specifies whether Copy option on transform commands is stored or not.
That is a useful command, thanks.
