Rotate a block instance around fixed point
I am working on a plugin for a company and one step in the plugin is to move many objects with x and y offset and with a rotation around the Z-axis.
The x and y offset was no problem with a translation transform. But I have problems with the rotation.
If I try to rotate the objects with GeometryBase.Geometry.Rotate(rad, Vector3D.ZAxis, referencePoint),
it will rotate all reference instances right but my block instances stay the same.
Is there a way to rotate blockinstances around a point is my question?
My code example that doesn’t work for me.
RhinoGet.GetMultipleObjects("Select objects to move or none to move all", true, ObjectType.AnyObject, out ObjRef[] refs);
List<RhinoObject> objectsToMove = (refs != null)?refs.ToList().ConvertAll(rRef => rRef.Object()).ToList():doc.Objects.GetObjectList(ObjectType.AnyObject).ToList();
foreach(var obj in objectsToMove)
        obj.Geometry.Rotate(DegToRad(inst.ZRotOffset ?? 0), Vector3d.ZAxis, inst.ReferencePoint);
        obj.CommitChanges();
doc.Views.Redraw();
I also tried to first declare the InstanceObjects as InstanceObjects in the code but that also didn’t work out for me.
Does anyone know a solution?
Hi @ian6,
Does this help?
  var result = RhinoGet.GetMultipleObjects("Select objects", false, ObjectType.AnyObject, out ObjRef[] objrefs);
  if (result != Result.Success)
    return result;
  var xform = Transform.Rotation(RhinoMath.ToRadians(45.0), Vector3d.ZAxis, Point3d.Origin);
  foreach (var objref in objrefs)
    doc.Objects.Transform(objref.ObjectId, xform, true);
  doc.Views.Redraw();
  return Result.Success;
– Dale
Hi @dale,
This works for me! Thanks!
