I am unable to set the slope of the roof slabs.
I am trying to set the slopes of all the slabs to 49 degrees in the properties panel.
Hi @ME_Mark,
It seems you find a new bug in VisualARQ 2.0.16. Iâve been investigating, and the bug is in the code that checks that the slopes are valid. More in detail: the slope angle is clamped between -90Âș and +90Âș minus a tolerance, to avoid completely vertical slopes. The problem is that we used the âdistance toleranceâ, instead of the âangle toleranceâ, so in a millimeters document, the tolerance is 1.0 units, which in angular units (radians) is almost 57.3Âș, so you can only insert values beteween -32.7Âș and +32.7Âș.
Iâve already fixed the bug in VisualARQ 2.0.17. Here is the latest installer for Rhino 5 (64 bit) if you need it now:
https://visualarq.s3.amazonaws.com/download/visualarq-2.0.17.11918-rhino5-x64-setup-snapshot.msi
Thanks,
Enric
Thank you!
