Hi @djhg the area of VisualARQ objects that had solids subtracted should be recalculated in tables. This works with VisualARQ 2 and VisualARQ 3. Make sure you update the table after any change on the 3D objects. If you have an example where this is not working, please send it over!
Thanks Francesc, but it’s not working for me. I suppose it’s incorporating the subtractions in the volume but it calculates the areas of both roofs in the image and project attached below as if there are no subtractions. Maybe I’ve inadvertently triggered an option to exclude subtractions? I wonder if I need to check to see if it’s calculating slabs correctly on the six projects I am working on:
