RoboDK - Robot Programming in Rhino & Grasshopper
RoboDK is offline programming software for industrial robots. It is used by professionals in many industries, including aeronautics, automotive, art, and architecture, to name just a few application areas.
There are many benefits to using RoboDK. For example, if you work in a manufacturing environment, one of the biggest benefits is that the software allows you to program the robot without interrupting the production. This saves time and money. Or, if you work in product design or architecture, the biggest benefit may be the ease-of-programming and the huge flexibility provided by using a robot to construct your prototypes.
RoboDK makes it very easy to turn CAD models into robot code. It supports over 300 robot models from over 30 manufacturers, which you can access in the Robot Library.
The new RoboDK plugin for Rhino allows you to easily use the powerful features of Rhino with the simplicity and dependability of RoboDK.
Download RoboDK on food4Rhino…
Posted Jul 25, 2018 by Carlos Perez on Rhino News, etc.
