RMB drop-down menu
Dear David, I don’t know if you’re a Grasshopper. I would like to ask you a question. Since yesterday the drop-down menu, which opens with the right button of the mause, is no longer extended but reduced. I enclose an image to make you understand the problem. Can you tell me how to get back to the extended menu? Thank you.
(Attachment Menù a tendina esteso.docx is missing)
Hi - please start a new thread for issues that are unrelated to a previous thread.
The MS Word *.docx format is not supported as an attachment on this forum. If you are trying to include a picture, either just paste that from the clipboard or drag it into your message from Windows Explorer.
immagine
immagine
Hi - please don’t start new threads with the same issue - I’ve now merged your new thread into this one…
As for the RMB menu on components, that behavior is completely normal and depends on the component that you are using.
HTH,
I apologize for the repetition of the question. However the menu is not working properly. In commands where there should be an extended menu is reduced. Yesterday, however, it was working properly. I think I typed a few keys unintentionally.
Hi - the picture that you posted was too small for me to be able to tell which component you are using there. Could you explain which component that is or post the .gh file?
The menu at the top is from a very old version of Grasshopper. It contains the options for data matching, which have since been removed. It also contains as submenus the menus of the input and output parameters. This is no longer the default, but you can get those back via the Preferences:
The picture you posted (Nickname, Preview, Enabled, Bake… and Help…) is the expected menu layout for a normal component.
The command in this case is rotate, but the problem applies to many others. I’ll attach you Nerves files of grasshoppers and images… I’ve also tried the “grasshopper setting” parameters in sectarian mode but they don’t create the full menu for me.
alphonso peluso nervi.gh (21.4 KB)
Like I said, the “Shortest List”, “Longest List” and “Cross Reference” menu items aren’t available any more in recent versions of Grasshopper, these options have been replaced by specific components.
The “Input:X” and “Output:X” menu items can be brought by by enabling that option in the preferences.
