I am building a roof using Rhino. I made sure all faces were planar before reconstructing the the roof in Revit. I am getting what seem to be ‘ghost’ creases that are not actually defining any geometry. I have tried resetting the geometry, updating the points in revit, and creating a new roof. Having the lines are not make or break but I wanted to understand if there were a ‘bullet proof’ way of resolving them.
I have attached the script I am using with internalized data.
I was using the planar surface tool as a way of checking that the points were all at the correct height (in plane). I guess there is a tolerance for what rhino considers to be a planar curve?
They are slight variations, so most likely below the Absolute Tolerance or Display Precision, or using a text panel to view which will mess with floating point numbers like these.
