Hello
I am trying to extract the deformed curves that form the a shape edited floor.
from RhinoInside.Revit.Convert.Geometry import GeometryDecoder
sse = F.SlabShapeEditor.SlabShapeCreases
for cc in sse:
print(GeometryDecoder.ToGeometryBase(cc.Curve))
print(GeometryDecoder.ToCurve(cc.Curve))
Runtime error (NotImplementedException): The method or operation is not implemented.
Is it actually not implemented or am I doing something wrong.
The creases are Curve class Curve Members
Is there any other way I can rebuild the curves in Rhino?
I just tried the new version 1.5 RC2 and it works almost perfect. I have noticed that some of the internal “Auto” boundaries are not exporting. I am using the code from your last example where you just use .ToCurve(). Is there are way of geting them as well. I have attached my test file, although it is not too hard to reproduce. Thanks. 220209_test.rvt (1.6 MB)
