Hello all:
my Rhino landscape project use in true coordinate, so it is far from 0,0,0 ,
in revit project , we have to set the project base point to 824750.0, 833000.0,0 ,
so the component seems not work base on that issue
i have set the rhino model base point close the revit but it seems not work , may i know what is the correct workflow for that ?
For the project progress , i started a revit project with default setting , i.e project base point 0 ,0,0, and i move all rhino elements to rhino 0,0,0 then started the RIR works , all components works available
Thanks all
