RIR Orient command in Revit
Hi all,
I wonder if there is an “Orient” command in Rhino.Inside.Revit just work similar to Rhino’s orient.
What I want to do is to create a family on the Rhino and Revit’s origin, then use the RIR orient command to put the family on to the right location and orientation.
I know you can put the object on the right location in Rhino first then use RIR to add it to Revit, but this is not what I want. Because it will result in within the family, the form will be far away from the family origin.
Thanks for any suggestion.
Use a plane to place the family and it acts as an orient. I think there is a sample here: RiR insert on plane orient sample
Some families only will insert and instance that is in only z direction. So, that needs to be watched also.
Cool~Thanks Scott!!
