Hi Guys,
I got a model generated in RIR but when I go to revit space, I cannot select anything?
Any help?
thanks
Hi Guys,
Any help?
thanks
Can you provide some context as well as system info?
Typically this is one of two things. Either Revit lost context (Save & Restart Revit) or you have select pinned items unchecked.
Thanks Japhy, to elaborate more, when I generate my grid from RIR and when back to revit screen and I cannot select my grid, please see attached gif file, thanks.
I am wondering if the error mode is something to do with this, currently the error mode is default to skip.
thanks,
Hi @sketzjewel ,
So as Japhy mentioned above, you should make sure you check select pinned elements shown below.
Usually when elements are created from RiR, they are tracked and pinned until you release them, once you release them RiR components no longer keeps track of the created elements in revit and any recomputations would result in duplicate items if nothing is changed in the definition…Check THIS page in the element tracking section for more information about it.
Hope this is the case on your side, and if not let us know.
